I have a fixed sat. system and am looking to add another seperate motorised system,but can only use the one cable (at present on the fixed dish), for both systems.I am going to use a diseqc operated motor via the reciever, therefor my question is can I switch between the two LNB's also using a diseqc switch and swing the dish with the same reciever.Also how do I connect the two recievers to be able to watch either system.Is there a reciever and or swithes that will do this.The reciever needs to have a multi card reader and compatable with the european satellites. Confused. Thanks in advance.ROB.
