Hi guys,
I'm new to this forum, and have read many of the articles you guys posted. I think there's a great knowledge base here and I'm glad I can learn from you.
Here's my problem:
I got an upgraded OTA antennae installed today (it took a flakey installer 4 appointments to get this up), however, I cannot receive any off the air signals. The installer didn't stay long enough to verify that the channels would come on.
Voom, under the system information panel, actually displays my OTA signal/power to be both around the high 70's to low 80's. The power's NBR is about 20.
However, I'm simply baffled why I am not receiving any off the air channels. I peeked at my room and saw that the satellite is pointing west downwards (I live in the SF bay) and that the antennea is pointing slightly north, which both should be correctly positioned.
I also asked my installer whether the diplexor was installed correctly, and he said that if it weren't installed correctly, then my normal voom channels wouldn't be showing up either (Voom channels worked fine). So now, I'm stuck trying to contact Voom's customer support to get them send someone else over to check my connections.
Is there anything I can do in the meantime that may fix this problem?
Here's my problem:
