Hays, NC 28635
Latitude 36° 18.600'N Longitude 81° 6.966'W
Sat Name Sat Lng Az(t) Az(m) El Skew
*** All Satellites 61W - 160W ***
EchoStar 3 61.5W 149.0 156.4 43.0 -24.6
Rainbow 1 61.5W 149.0 156.4 43.0 -24.6
Brasilsat A2 (incl. 5.8 deg) 63.0W 151.1 158.5 43.7 -22.9
Brasilsat B2 65.0W 154.0 161.4 44.5 -20.7
Brasilsat B1 70.0W 161.6 169.1 46.2 -14.7
Nahuel 1 71.8W 164.5 171.9 46.7 -12.4
AMC 6 72.0W 164.8 172.3 46.8 -12.2
Galaxy 12 74.0W 168.1 175.5 47.2 -9.6
SBS 6 74.0W 168.1 175.5 47.2 -9.6
GOES 12 75.0W 169.7 177.2 47.4 -8.2
AMC 5 79.0W 176.4 183.9 47.8 -2.9
DirecTV 3 81.8W 181.2 188.6 47.9 0.9
Nimiq 2 82.0W 181.5 188.9 47.9 1.2
T/South(close)
Brasilsat B3 84.0W 184.9 192.3 47.8 3.9
XM Roll 85.0W 186.5 194.0 47.7 5.3
AMC 9 85.0W 186.5 194.0 47.7 5.3
AMC 3 87.0W 189.9 197.3 47.4 7.9
Galaxy 9 91.0W 196.4 203.8 46.6 13.1
Galaxy 11 91.0W 196.4 203.8 46.6 13.1
Nimiq 1 91.0W 196.4 203.8 46.6 13.1
Brasilsat B4 92.0W 198.0 205.4 46.3 14.4
Telstar 6 93.0W 199.6 207.0 46.0 15.7
Galaxy 8I (incl. 1.0 deg) 95.0W 202.7 210.1 45.4 18.1
Galaxy 3C 95.0W 202.7 210.1 45.4 18.1
Telstar 5 97.0W 205.7 213.1 44.6 20.4
Inmarsat 2 f2 (incl. 1.7 deg) 98.0W 207.1 214.6 44.2 21.6
Galaxy 4R 99.0W 208.6 216.0 43.8 22.7
DirecTV 2 100.8W 211.1 218.6 43.0 24.6
DirecTV 1R 100.8W 211.1 218.6 43.0 24.6
AMC 4 101.0W 211.4 218.8 42.9 24.8
DirecTV 1 101.0W 211.4 218.8 42.9 24.8
AMSC 1 101.1W 211.6 219.0 42.9 24.9
DirecTV 4S 101.2W 211.7 219.1 42.8 25.0
AMC 1 103.0W 214.1 221.6 41.9 26.9
Solidaridad 1 (incl. 2.8 deg) 103.5W 214.8 222.2 41.7 27.4
AMC 2 105.0W 216.8 224.2 40.9 28.9
G-Star 3 (incl. 11.5 deg) 105.0W 216.8 224.2 40.9 28.9
G-Star 1 (incl. 6.0 deg) 105.0W 216.8 224.2 40.9 28.9
MSAT 1 106.5W 218.7 226.1 40.1 30.3
Anik F1 107.3W 219.7 227.1 39.6 31.0
Anik E1 109.2W 222.0 229.4 38.5 32.6
DirecTV 6 109.8W 222.7 230.2 38.2 33.2
EchoStar 6 110.0W 223.0 230.4 38.0 33.3
EchoStar 8 110.0W 223.0 230.4 38.0 33.3
Anik E2R 111.1W 224.3 231.7 37.4 34.2
Solidaridad 2 113.0W 226.4 233.8 36.2 35.7
Morelos 2 (incl. 4.4 deg) 114.9W 228.5 235.9 34.9 37.1
XM Rock 115.0W 228.6 236.0 34.9 37.2
SatMex 5 116.8W 230.5 237.9 33.6 38.4
Anik E2 118.7W 232.4 239.8 32.3 39.7
DirecTV 5 119.0W 232.7 240.1 32.1 39.9
EchoStar 7 119.0W 232.7 240.1 32.1 39.9
EchoStar 5 119.0W 232.7 240.1 32.1 39.9
EchoStar 9/Telstar 13 121.0W 234.7 242.1 30.7 41.1
Galaxy 10R 123.0W 236.6 244.0 29.3 42.3
Galaxy 5 125.0W 238.4 245.8 27.8 43.3
Galaxy 12 125.0W 238.4 245.8 27.8 43.3
Galaxy 13 127.0W 240.1 247.6 26.3 44.3
Telstar 7 129.0W 241.8 249.3 24.8 45.3
Satcom C3 131.0W 243.5 250.9 23.3 46.1
Galaxy 1R 133.0W 245.1 252.5 21.8 47.0
Satcom C4 135.0W 246.6 254.1 20.2 47.7
GOES 10 135.5W 247.0 254.4 19.8 47.9
AMC 7 137.0W 248.1 255.6 18.6 48.4
AMC 8 139.0W 249.6 257.0 17.1 49.1
Inmarsat 2 f3 (incl. 1.9 deg) 142.0W 251.7 259.2 14.7 49.9
EchoStar 1 148.0W 255.8 263.2 9.9 51.4
EchoStar 2 148.0W 255.8 263.2 9.9 51.4
TDRS 9 (incl. 7.4 deg) 151.0W 257.8 265.2 7.5 52.0
TDRS 10 (incl. 6.2 deg) 151.0W 257.8 265.2 7.5 52.0
EchoStar 4 157.0W 261.5 269.0 2.6 52.8
motor elev.= 54 deg.
Dish elev.=24deg
(Just these two angles need to be set one on motor and one one dish, never touch the motor elevation after setting it, the dish elevation may need moved up or down slightly to get the maximum signal quality, use the signal quality meter only)
As mentioned above make sure your L.O. is set correctly for the LNBF you have.
I use the below TP. to find AMC-5, Use USALS after entering your latitude and Longitude in the AMC-5 antenna set up screen, do not touch the limits at all unless you think the dish will hit something when it moves.
Freq. 11808MHz (H) SR : 4.164 Msps
http://www.adventistsat.com/downloads/Install_fortec.pdf
http://microyal.com/h2h-install.html
