I am getting throttled over here. Been working with this for a week now and have literally got nothing still. I just don't get what I'm doing I guess. I think it's cause the instructions I'm using look nothing like my dish
The one with 2 larger wires in with the smaller wires is for the motor. The two larger are for the actual motor and two of the smaller in the same sheath are for the reed switch.
The other bundles of all small wires are for a polarotor if you choose to use one. If you are using just an LNBF then you will not need those wires.
Also note take the bare wire and use for ground, but only ground at the house or at the dish and not both.
What receiver and dish mover are you using?
Correct you will need smothing like a vbox. If you have the wires going to the LNB/Feedhorn that is the polarotor. To move that you will need a Titanium ASC1.
It does have a learning curve, but once you figure it all out you will be glad you did and enjoy it!!
Don't be afraid to ask lots of questions.
Lots of info on here so just search and read and read and read. Also, like I said don't be afraid to ask. We have all started out just like you at one point.
It truly is a fun hobby.
See my PM.So what one is better? The actuator or the polarotor. What one do I want to use? I don't want to buy 2 extra boxes.
Here's the lnb
That's the guide I was using. I got the manual though from someone and it looks extremely close to mine. I think after watching some videos I have a better idea now, and looking at the manual for my dish. I still little list on all the focal point and all that. Also now I need to find something that can run My polarotor and motor..... Since I found out I have a Servo too. I found locally a Motorola 4dtv 922. She wants little money or says I might have it free she doesn't k ow yet. I need to know If this will run the actuator and polarotor both? Then how do I get that to my receiver though.This may seem a little overwhelming at first, but you may want to look over this website and instructions.
C-Band Polar Mount Dish Installation Guide - TVROSat
Lots of good information in there. Don't give up, you'll get it. You have a lot of it done already. You can skip past the stuff that's done.
Besides putting that angle finder in all the wrong places, you have to have found your true NORTH!! Then and only then, use that angle finder!Okay guys. I have been working with this thing for weeks now and I honestly think I'm worse then when I started. Seems the only say I can ever lock onto is 121 w and now I can't even do that..... I attached a bunch of pics. Where exactly do I measure declanation angle. As you can see I put the angle finder in like 8 spots would you guys tell me what picture is the right one. Every spot gives dramatically different angles. I know where to do the elevation I attached thst pic as well. That is easy. Also I found the guide on chaparral on where it says to point the long side of the servo motor to 11 o clock to the polar axis? This seems to have made things even worse. I can't find any thing. What in the world am I doing wrong. I didn't know you had to be a mad scientist to figure this out.
