you can bend the bottom of the poles at the two ft length to make an elongated check mark, take one of the poles and cut off say 3 ft, place both poles in the bucket with the bent up tail pointing into the middle and the main body of the pole at the outerside of the bucket, this will look like two straws of varying height in a glass standing at either end of the glass. The varying height will allow for the dish's to have greaer swing radius but your new concern will now be the added wind surface of the added dish so you may want to consider adding some lead weight to the bottom of the bucket or atached to the outside of the bucket.
