Hello,
I have a small hospital group with 5 patient rooms that each have a digital receiver off DirecTV. Seems any time two TV's are on, all is fine. When the third or fourth go on, others drop out. DirecTV was out and said it was due to the legnth of cable between the roof (14 floors of RG-11) and receivers, and were receiving a -60 at the splitter outside the first patient room. They said I needed an Amp.
Blonder tongue rep sold me an LDA-50, L-band amp. WHen I installed it up at the roof level, nothing worked. I was then told it was because I needed a Power Inserter, as the LDA-50 did not pass power to the LNB's. DirecTV came out and moved the Power Inserter (PI -21), to the LNB side of the amp and we still had no signal at all down at the receivers, (whereas we had some signal with no amp). 120VAC Power to both the PI and amp is good.
I noticed that the antenna had 3 LNB's attached. DirecTV said this is to get multiple satelites. Yet I saw only one trunk cable. Does this sound right? Can anyone offer any advise on what I can try next?
Thanks!
Joe
Thanks!
Joe
