Help with 522 hookup
Mopee
16
Walla Walla, Wash.
I am hooking up a 522 with a quad lnb. I don't want to run two wires into the house. Is there a switch that will combine feeds from a couple or one of the lnb nipples to a switch then into a single wire then split the signa to the two feeds, sat 1 and sat 2, on the back of the 522?
m
Get yourself a DPP twin then you can use the DPP seperator on the 522 and only run a single cable. You could also go with a dish 1000.2 or DPP44 but those would be much more costly.
My Dishnetwork HD Upgrade Horror Story.
622 not seeing satellites (110, ?)
