Hi. Looking for a little help.
I would like to know what equipment I would need. I live in the Boston area. Should I get a Slimline dish with the 3LNB or the 5LNB? Is the 5LNB overkill? Do I need that for my locals or would the 3LNB cover it? Would I be missing anything if I didn't get the 5LNB? From what I understand, using the 3LNB means I will not receive the 110 and 119 sats. Do I want those? I know sometimes HD and SD locals are carried on different sats. I plan on having (for now anyways) an HD DVR box and a standard (not HD) box. So I need both HD and SD locals.
Also, is the SWM Slimline the way to go? The way I understand it is that the obvious benefit is that you only need to run 1 coax from the dish and can split that for 8 separate tuners. Of course, with the SWM you have to use the appropriate splitters and the power inserter. Do you only have to run ONE coax to an HD-DVR (HR24)? Does the box split the signal to both tuners internally or do I have to use both inputs on the back?
Is there a downside to the SWM Slimline at all?
The power inserter can be connected in-line right? It does not need it's own port on a splitter?
Sorry for the stupid questions . Any help appreciated!
