I've got a 10' mesh dish and a Toshiba trx-80 reciever.
I haven't used it in a few years but decided I'd fiddle with it. It came with my house and I never really used it, I put in a DirectTV system. When I played with it then, it was reporting "no pulse from actuator".
I bought a new sensor for the actuator and installed that today. Now it doesn't say that message anymore.
However, it doesn't want to go east/west very well. At first, the dish wouldn't move at all, so I took the motor off of the actuator and rotated the tab sticking out of the actuator arm manually with a wrench and the dish moved.
I looked at the motor and had my wife press west on the remote. You could see the motor rotate maybe an 1/8th of a turn each time she would press it.
I checked the voltage at the reciever and it makes a number above 12v most times, but it's only there for a brief moment and the meter doesn't really have a chance to read it the same each time I guess. Same thing out at the motor, I checked the voltage at the brush end of the motor and it's getting a signal which sometimes reached 20+ volts, but only for a moment.
I put the motor back on and it would then move the dish, ever so slightly.
Shouldn't I be able to press east or west when setting the dish limits so that it continually moves?
Right now when I press east or west, the receiver makes a click noise (it sounds like 2 clicks extremely close together), puts moving east (or west) on the screen and then seems to go blank on the receiver display and then it all comes back to normal.
Each click makes the dish arm move about 1mm. It's really very slight, you have to put your finger on the arm to feel it move.
What should I look at next?
