Help!!! Receiver only works though PS3!!!
quint
USA
I recently connected my receiver through a splitter that was connected to a second tv which also was connected to a Playstation 3, now every time I disconnect the PS3 to play my XBOX 360 the satellite receiver in the main room loses signal! I have since tried to eliminate second tv with PS3/xbox and connect the main tv directly from receiver box to main tv and can not get any signal, if I connect back to second tv with PS3 connected the signal strength is again fine :confused: I have never had this problem or any problems making a connection it all seems very strange to me, I have unplugged the receiver for several minutes and tried to replug into main tv hoping it would reset and work but no luck.
I hope someone could steer me in the right direction to resolve this problem, thanks in advance.
Basics: Cable from dish to the DirecTV receiver.
Output of DirecTV receiver to the TV and your PS3 and XBOX also are connected to the TV.
connection that works: satellite cable into receiver input,
out to vcr/input out to splitter into 2
TV's The PS3 is connected to 2nd tv through RCA cable
connection not working : satellite cable into receiver input out to (1) main tv input
I don't understand what this means.
Please elaborate as to what Input and outputs you are using on each piece of equipment. .
R15 Cropped
HD Response from DTV
