I just installed a new triple LNB with built in multi-switch dish on my house. I do have a few trees in the backyard, but I belive they are all below my horizon line. I have tried several (like 10) different mounting locations, all with the same result. Sat A (101) is 96-99 signal strenght, Sat C (110) is 95-97 signal strenght, but I cannot get ANYTHING for Sat B (119). I have a few questions to help me trouble shoot the problem. When looking in the direction of the satillites, do the ascend from right to left or left to right? Basically, by my logic, 101 will be at my right, 110 to the left of that and 119 to my far left. Is this correct or am I backwards? I also did the tinfoil test and found the sinals coming into the LNBs as follows. If you are looking at the back of the dish, and the front of the LNBs, 101 is the one on the right, and 110 is the middle. Covering the one on the right affects neither 101 or 110 so I am assuming that is 119.
What am I doing wrong? Again, I am not ruling out a tree in the way, but based on where the trees are I cannot see 101 and 110 being so strong and 119 being nothing.
BTW, my ZIP is 32810 and my dish is set at 233 Azimuth, 44 Elevation and 49 Tilt. I tried upping the elevation a bit to no avail.
Could my LNB's be a problem (one defective)?
I apologize for the long post and any insight would be appreciated.
Thanks,
Josh
Thanks,
Josh
