Help me hook up my HDD 200.
coinmaster32
916
14
USA
Componet cable running between HDD 200 and Tv. Switch set to ybpr. Res set to 480p.
S video cable from 922 going to hdd 200.
Both receivers are powered on.
MMAP cable is hooked up between hdd 200 and 922.
No video through the hdd 200. Nothing shows when pressing buttons on 922 or trying to access the menu on the hdd 200.
I think you get a "spash screen" of sorts out of the component cables... no matter what source (mmap hd , svideo or composite) It auto detects svideo / yellow video input if there is no mmap input...
Don't know what you want to do with it. I don't know of anything up there in 4DTV land that is worth bothering with.
You could use it as a line doubler but you need a manual for that. The thing is quirky also & does not work every time.
Old Tech.
I wonder if its dead?[/QUOTE
Do you have the manual? Mine has component outputs and I have used those & audio out with
good results. Use TVRO's suggestion for a signal source. I think your TV should be able to handle the component source. If you get everything right the 1080i will give you a really great picture. On the input you normally use for your 4DTV you will only get sound & no video.
:cool:
Signal @ 10%
Glad to have my 4DTV
