Here's what I have. A dmx741 lnbf on the big dish, and a ku lnbf on the small dish. The ku is running throw the 22khz switch of the dmx741. I can receive H and V on the ku, but not on the c-band, only Vertical tp's. So I assume the right voltage must be making it's way out to the lnbf's. (Side note) the small dish is mounted to the big dish, so the alignment should be ok if I'm getting ku. What else should I check before assuming the C-band lnbf is bad? Any help would be appreciated. Thanks: Long Hair
