I am trying to install a second Satellite/receiver on my garage/shop. My friend gave me his Sat Receiver and dish. He jumped companies, and I know the two worked up to three weeks ago when it was pulled down.
Anyhow, I mounted the dish and hooked it up to the receiver and tv, right outside next to the dish so I could see.
I used to move all the time and have done self installs many times, but this unit is a little different than my home unit.
It has one molded lnbs, where my home unit is a two piece. The new one has one cable connection on each of the units, where my home unit had two.
I didn’t know any better so I hooked a sw-21 to the two cables and did a switch test, it found nothing. I then looked on the net and discovered I did not need the sw21 I had just bought so I hooked up one of the cables direct, with no switch.
I ran the test again and it could not find the switch. I tried locating the Satellite by just setting it to look for 119, and could not find anything, I mean nothing. Not a wrong satellite, I mean nothing.
What am I doing wrong, help help help.
I am pulling my hair out.
Should it find the switch even if I don’t have signal from the satellite?
Thanks a bunch
Thanks a bunch
