DirecTV is asking for our help in troubleshooting the 22 or 62 error message related to network setup.
If you have seen this error, and are network savy, please fill out the survey at this address:
http://www.iamanedgecutter.com/projects/2262/default.aspx
It's been asked that you take the survey if you have seen the error in the past, or see it now. If it happened in the past and has stopped, please just note that in the comments section.
This information will be used only by DirecTV, and only for troubleshooting the 22 / 62 network error situation.
On behalf of DirecTV & Satelliteguys, Thanks for your support and feedback!
Some info regarding where to find the error:
You may get the error when you are either trying to SETUP the network connection, or test it. This is actually an error with the internet communications, so it may affect DoD and Network Services. You should see the error code during the testing, but you may also see the error code in the system information screen.
