So I am about at the end of my rope. I spent most of today trying to get my dish aimed and still am having all sorts or rain fade with clear skies (mostly locals). Both receivers have the same problem. I would appreciate some help and if my post is in the wrong place, please move it accordingly.
First, my setup is as follows....
Located in ZIP code 37931, DTV slimline 3 LNB --> 4x RG6 --> zinwell WB68 6x8 multiswitch --> 2x HR24 /w 2x B band converters. I have a clear view of the sky.
The mast is perfectly plum. The 101 comes in fine, all transponders are 96+. I set the elevation, azimuth and tilt as per spec (El=44.6, Az=210, T=22) and using the Az and El, peeked the 101 using transponder 1. Does it matter which one?
Next I switched to the 119 and adjusted the tilt (very little change needed) and peeked it. I went back to the 101 and it was still good.
But, unlike what is said iin other threads, the others did not fall into place. The 99s is the worst, below are what transponders come in:
1-8: 0,53,0,0,90,0,na,na
9-16 na,na,na,na,na,na,0,72
17-24 81,76,76,0,34,0,0
25-32 all na
No amount of tweaking either of the 3 adjustments yield any improvements. Side note, all the signal screens populate transponder strength numbers quickly except for 99s. Most transponders show up really slow but some go fast (99s only).
This has been like this for a while (year maybe?) but Ive not messed with it because everything worked. Now, the locals and some HDs are completely unwatchable.
Is there a way to know what transponders and birds I need so I can tweak to those?
Am I doing something wrong? Any suggestions? This is driving me crazy.
25-32 all na
