Help adjusting Fortec 8 footer for eastern birds
Blindowl1234
2,035
94
SouthWest Ohio
I've been doing some tweaking of my 8 footer before the weather starts getting cold. Since most of the leaves have dropped now I've been experimenting with getting a solid signal on 58w-83W sats. If I raise the dish elevation 2 degrees I get 58-83W ok, but I start losing the 131w-139w sats. If I leave the elevation as it is now I get 87W thru 139W perfectly. I'm thinking since 87W is roughly my true south that I need to shift the dish on the pole slightly east? or west?
Anybody have any other suggestions? Thanks Blind
Sounds like your declination is off a bit. Basically, to fine tune it, Put a mark on the mount that will be transfered to the pole. Do an Azimuth adjustment on the east side of the arc and transfer the mark on the mount to the pole. Repeat on the west side. You'll have two marks on the pole for the one mark on the mount. Adjust the declination slightly, and touch-up the elevation at Zenith. Repeat east west azimuth alignment. You want the marks on the pole to come together. If your marks spread apart, you've adjusted the declination opposite of what it needs.
Thanks Fat Air....I do some experiments in the morning and see. I moved it on the pole about an 1/8" to the east and the signal strength is actually better than it already was....Still no luck on 58-72W....will try in the a.m.
Blind
How to check a 920 to see if the old channel maps are still intact
Last of the BUDS in my area now gone
