HD Resolution
EEJay
SatelliteGuys Guru
144
Has anyone done any tests to see what they transmit? I know Dish is putting out 1080i at 1440x1080 and DirecTV's garbage is 1280x1080.
Thanks. I have the Internet, and TV should be here in Germantown in March. Just doing a little research, but it looks like I'll switch.
PQ is the real reason to switch, or at least was for me. The DVR is so-so, and perhaps I'm counting on too much for the 2nd roll-out of the software around April, but hopefully Verizon will address all the issues of the DVR... but the PQ... very nice.
PQ was one of my reasons, :cool: value was the driving force for my decision - higher speed than cox, more channels and better PQ than Directv, a real HMO network (capabilities limited now, needs to be upgraded by V*)
If you have a 1080p TV (preferably, one with 1:1 pixel mapping), set your FiOS DVR to record the "off air" program on Hdnet from 6:50am - 7am EST every Sunday morning. This "off air" program consists of test patterns, including a resolution pattern for 1920x1080.
DirecTV and Dish Network typically test in the 1100-1200 range while most cable providers test in the 1400-1600 range. Very, very few cable providers carry a pristine signal that can pass the full 1920.
To some extent, this is also a test of the video processing in your TV and in the set-top box. If your 1080p display doesn't do acceptable 1080i->1080p deinterlace, it may skew the results. If you have a Tivo Series3 and a FiOS DVR, it would be worth comparing the two on this program.
new to site
Shaw Cable Motorola 6416/6412
