HD receiver on Phase3 dish
This1
261
Florida
I am having a issue with my HR21-700 on friends phase3 dish I get signal when I go to menu But when i put the channel on I see 771 searching for signal
I had this receiver on a slimeline and changed to a phase3 dish is there anything I need to do to get this to work correctly thansk
If your getting the 771 error on the HD channels you are out of luck. The phase 3 dish is pretty much only good for picking up SD channels now.
I am getting that on SD channels was't sure if something needs to be changed in settings on reciever.
I did a new setup and I get XXX on some of the satellite like 110/119 which are not needed
The Phase III "sees" the sats at 101, 110 & 119. The HD signals come from from the 99 & 103...which the Phase III is not designed to "see." It is a mechanical thing designed into the dish & LNB
This is not the same thing as the 3 LNB Slimline dish that "sees" the 99, 101 & 103.
Joe
i understand that I am only using it to recieve 101 and SD channels get 771 also teh guide is greyed out
Menu
Parental Favs & Setup
System Setup
Display
Preferences
Then under the Guide HD Channels drop down, select "Hide HD Duplicates".
Was the slimline an SWM? (only 1 coax to the receiver) If so, that's probably what your problem is. You need to go into sat setup & change the dish to P3/multi-switch. (it might be on SWM instead, which will NOT work)
Question about install today
Pricing Inquiry
