I have a question about picture quality on my 811 and Mits 48" HD monitor. As I was watching ESPNHD tonight, the picture quality was less than I expected. While the quality was certainly better than SD, some of the same effects showed up in the HD broadcast. On the regular angle showing the field, the grass looked solid with sort of a smooth, oscillating effect. Tight shots up close, looked much better. Is the problem my 811, E* network compression, my monitor, or a combination? I have noticed this on DiscoveryHD also. It has been less noticable on HDNet.
OTA HD broadcasts have a different set of problems. My PBS feed has pixelation with any fast movement. All have the sound problem described in other posts, it is not in sync with the video and frequently the sound drops out. The picture also shows "blotches" and other digital artifacts. These are also on the sat channels, but to a much lesser degree. I also have the slow frame rate, although this is not as bad on this 811 as it was on my 1st one.
I have the 811 hooked up through all inputs, these problems are the same no matter which one is used. Any comments or help would be appreciated. I don't know if D* would be any better, or cable, which will be available in my area in 2005.
