Is there anyway to avoid showing both channel numbers (higher and lower channel numbers) in the ALL HD programming guide? I'm tired of seeing the channels twice as I scan the guide....
You can either shut off the map down feature located under Local Channels in the system setup, or you can set up locked channels and hide them by using the lock feature.
OK, I tried it but I wasn't sure what to do in that menu. It gave me choices for Local channels and DISH HD. Any help out there? I didn't see anything about map down options....
Anyone know if this will mess up scheduled recordings, if they were initiated on the mapped down channels?
I cannot get this to work. There is no map down to select under Local Channels in the menu. When I select disable under the DishHD Channels, nothing changes. Do we have to reboot the DVR?
Which receiver are you using? What dma?
