Hi, I have a couple questions about installation. I am getting the HD DVR, connected to only one television. So, what hardware will be getting installed? Am I correct in thinking that it would be the 1000+ dish, with a DP44 switch and a VIP 722 box?
The reason I am asking is that the installer had some problems yesterday. He had the VIP 722 box. Based on pictures I've seen here and at dishnetwork.com the actual dish is a 1000+, although he told me it was a 500+. It has the LNB in the middle and one on each side.
Now when he was trying to go through the setup, it would bring in the 110 and 119 satellites with 105 signal strength, then he would switch to the 129 satellite and it was 0, it never got any signal at all. I noticed on the screen that it said DP34. Everything I found online says you have to use the DP44 if it's the 1000+. So, how can I find out for sure what dish it is? Am I correct in thinking that if he hooked up a DP34 to a 1000+ dish that it would work, just wouldn't pull in the 129 satellite?
Also, when we turn on the 722 it defaults to dual mode even though nothing is hooked up in the TV2 output. It also won't let us switch to single mode unless you are on the screen that shows TV1 and TV2 where you select over the air, or cable (not sure what the screen was called).
Finally, neither of the remotes will work. However, if I go to the system info screen and press a button on the TV2 remote the little TV icon flashes when you press buttons. Any ideas on why the remotes won't work?
The installer is coming out again tomorrow, and I really want to get this finished and working. Any help would be appreciated.
