I have a dish 500+ pointed to 110, 118, and 119 with a vip722k. i have a extra dish pointed at 61.5 that i am not using. so i decided to repoint that 61.5 to 129 so i could get more HD channels (yes, i am subscribed to them). so i unhooked the dish 500+ from the receiver and ran check switch. then pluged the 61.5 dish straight into receiver and tried to aim it at 129 on transponder 17. the max signal strength i could get was 62, but the receiver did lock on to the sat. so i thignted up the bolts and i still had signal of 62. so after aiming to 129, i pluged that dish into the "lnb in" on the dish 500+( becuase it has a built in switch). i then ran a coax from the "out" on the dish 500+ to the receiver. and ran check switch. for some reason it was taking a really long time on step 4 of 4 on the check switch. therefore, i hit cancel and it showed green for sat 110, 119,118, and 129. For device for each sat it showed DB+ for 110, 119, 118, and for 129 it showed N.C. i don know what this means. but i exited out of the menus and it went to acquiring signal. then went to live tv. i looked in the guide and saw that all the HD channels on 129 were showing there. SO i tried to watch one of them and it just says no signal switching to sd. and sd works, but i assume that is becuase the sd is not on 129 but on one of the other three sats. i tired several more and all do the same. I went to point dish menu and see that signal had droped to 52 on transponder 17. I read online that many pep can watch with that much signal strngth so i tired channels on transponder 17 and still same thing. tried resetting and ran check switch again but still no luck. any idea what i can do? i dont see any LOS issues.. and i believe im using a legacy dish the 18" one. i have a extra dish 500 too.. but do not have the mast for it, but would that get better signal? and do you guys think low signal is the problem?
im from southern mississppi btw. i dont think it should be a problem aiming at 129?
