Have a Multi-switch Question
TYORK
1,039
indy
I am installing a D* 3 lmb with build in multiswitch question is i have tivo and 3 other receivers if i run 2 direct line to the tivo which would be the best multiswitch to use for the other 3 receivers. And what would cause the 110 not to work if 119 has 98 signal and 101 has 94 signal 110 0 signal.
thanks
The way I understand it (I dont have DIrectv so someone correct me if I am wrong), if you are going over 4 receivers, you need a 4x8 or 5x8 cascadable multiswitch, due to the way the original multiswitch is set up
100% correct IceBerg. No other way to do it and retain all three satellite.
As for your missing 110 ... look for a tree or other obstruction or a possible bad LNB.
looking 95 sat
Won't to get D* and HD
