My friend has a 1998 Chevy P/U with a 350. It's very difficult to start after it sits for a few days. If it's driven daily he has no trouble getting it to start. The fuel pump has already been replaced. Any ideas?
Sounds like the fuel pressure regulator. Its under the top half of the intake manifold. Its basically leaking fuel causing your engine to "flood". I had this issue on a 96 Tahoe.
Yep!So you are saying if it's allowed to sit a few days, fuel leaks past the regulator?
See post#4, what ruled out your suggestion.I would say a weak battery first and go up from there ruling things out. Maybe the truck is aying its time for a new one if the friend can afford it. Good Luck anyway. Let us know what the problem was!
Tom
+1 Very commonSounds like the fuel pressure regulator. Its under the top half of the intake manifold. Its basically leaking fuel causing your engine to "flood". I had this issue on a 96 Tahoe.
