Hello, all:
As someone who is a very large fan of certain PBS programming that doesn't appear on the 24-hour feeds (Red Green Show, McLaughlin Group), I decided to try to make as full a schedule as I could solely from observations of the feeds on AMC21.
Here is the link: RabbitEars.Info
There are several notes that I suspect will need to be used as an FAQ.
1) Any spaces in gray are test patterns.
2) Any spaces in red or in white represent signal problems on my end (my 75cm/30 inch dish is too small for the weaker transponders to be 100% reliable), times when I was not near my receiver or times when I was sleeping. Any information that would fill these gaps would be greatly appreciated.
3) Here are the PBS feeds I do not list, as they are available from Titan TV:
12072H - Louisana PBS
12106V - Montana PBS
12112V - Oklahoma PBS
12140V - PBS East HD (HD01)
12140V - PBS West HD (HD02)
12180V - Create (SD02)
12180V - V-Me (SD03)
12180V - World (SD04)
4) Here are the PBS feeds I do list:
12180V - HD03 (This is the HD feed on the Create mux)
12180V - SD01 (This is the other SD feed on the Create mux)
12151H - HD04
12163H - SD05
12169H - SD06
12175H - SD07
5) As this feed is from observation, some of the programs will not be seen on a regular basis and are likely one-time programs.
6) The programming on these feeds can change at any time as it is outside of my control. As such, my schedule almost certainly will not be 100% accurate, and should be used only as a guide for when to look for desired programming.
7) All times are in Eastern Time, my local time zone.
Any other questions I can answer will be added to this list. Opinions are appreciated.
- Trip
12151H - HD04
12163H - SD05
12169H - SD06
12175H - SD07
- Trip
