I have had dish network High Def service for about a month now, I am using the 622 DVR receiver. Yesterday (Sunday 12/23) we got a new entertainment center. I unplugged everything (the power frist and waited before moving it) took it out of the center, put the new one together and set everything back up the way it was. After all was hooked together the receiver went through its startup cycle except it had trouble establishing a connection. It would just say the sat signal had been lost, however, I am positive everything was hooked together properly. I reset the box several times with no luck. About two hours later it finally booted up and got a signal. However, once it was running I was missing about 3/4 of my HD channels. I rebooted, did the signal tests etc etc and everything is fine, but most of my HD channels persist in being missing.
I am located about an hour west of Philadelphia. My system uses 2 sat dishes and the receiver tells me it is using sat 110 and 119 both of which have good signal strengths. I spent about an hour on the phone with support and they had me do all the tests, resets etc and could not find anything wrong. Eventually he said that he thought that my signal from sat 129 was weak and that was the trouble.
My questions:
1)Am I even using sat 129 even though it doesn't show up in the diagnostics etc?
2)Is there anything that could cause the loss just some of my HD signals from just unplugging the receiver for a while.
3)Will fixing whatever the problem is cause the missing channels to appear back in my guide after a reboot or do I have to do something to make it relook for the channels.
Thank-you anyone for any help or insight you can provide....I miss my HD.
My questions:
