H2x & HR2x CE Release 1/20
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,043
448
Central Michigan
Systems in this CE
H21 • H23 • H24 • H25 (Except H25-700)
HR20 • HR21 • HR22 • HR23 • HR24
(all manufacturers)
Window of opportunity to download:
Friday, January 20, 2011 11:00PM - 2:30AM ET
Saturday, January 21, 2011 11:00PM - 2:30 AM ET
Risk Level for this Download: Customer Candidate
New features
None
Improved/Updated
Under the hood
MRV stability (H25)
Notes
If you revert to National, it will be to the blue UI
You will need to enter IAMANEDGECUTTER keyword search if first time STB updated to HD UI
You may lose your guide cache
Please allow up to 24 hrs to restore your full 14 day guide
Your STB may restart during idle time within the first 24-48 hours of CE download
Please do not report sluggishness or missing search results within the first 12 hours
Please send logs along with all reports, including MRV issues
Previous Release Information:
"Under-the-hood" and "stability" improvements are expected with every release and are not noted here.
New features
  • {CE:29:01} 0x058C/0X458C
  • Energy Star
  • YouTube and TV Apps launch icons
  • New key mappings
  • Trickplay will never work when the picture is in a window.
  • Playlist: {DASH} now brings up the Options menu (equivalent to {YELLOW})
  • Playlist: {PAUSE} now starts playing back the highlighted recording
  • Live TV/Recording Playback: {ENTER} brings up the mini-guide
  • Guide and Mini-Guide: {FFW} and {REW} now jump forward or back 12 hours (equivalent to {GREEN} and {RED})
  • Pressing {ENTER} on a highlighted program in your playlist will toggle it to KEEP and back, like {BLUE} button does now.
  • {DASH} now brings up the guide options while in the guide.
  • {DASH}-{DASH} no longer functions to delete an item from the playlist.
{CE:29:04} 0x0592/0x4592
Dvrs only: Pandora Radio
Improved/Updated
My DIRECTV
Menu Icons
2 Second banner
Under the hood
{CE:29:02} 0x058D/0x458D
My DIRECTV
Menu icons
TV resolution Checkboxes
Progress bar improved
{CE:29:06} 0x0596/0x4596
Energy Star OSD
Pandora launch (HR only)
{CE:29:07} 0x0599/0x4599
Energy Star stability
Pandora/YouTube stability (HR only)
Can someone explain what the second number in each model number means?
For example: H25-700
My receiver is H25-100 what is the difference between that and the 700?
Different manufacturer. To you the end user, there is no difference. It's only different under the hood, and only meaningful to the programmers writing the code for them.
Makes sense, thank you!
Wow. It's early, but I'm seeing a HUGE improvement in MRV responsiveness on H25 to an HR34.
does anyone know where or how to get pandora running? I do not see anything on either my HR21 or HR24
It takes time to pop in, may take several days to show up.
Once it shows up, you need to go to the website it tells you and give the code it gives you and you'll be up and running in a few minutes.
Updated HR24 and H25. For the first time ever after a CE update, I don't have to unplug/replug the HR24 to make whole home work on the H25. YAY
which one is the newest ce software update that just came up this weekend? i downloaded the software and have the 0x59c version for my h24-100 receiver. is this the one i need to get the newest ce tweaks and also where does the pandora and youtube stuff pop up at? under what window of screen? is it under the tv apps or where? just trying to understand where to look for it to use it. thanks for any help
Yes, you have the newest CE software and you would look under Extras
CE's for the Weekend of 1.27
HR34 CE Release for 1/27
