PLEASE READ THIS FIRST! DirecTV Cutting Edge Program: Terms, FAQ, How-To, Hidden Features, and More
If you have any issues with this CE release, please post them in this thread. We'll try to help, and DirecTV will see / be aware of your issue
For the latest updates, check out the Satelliteguys CE Chat on Friday nights:
chat.satelliteguys.us
Friday, 8/14/2009, 11pm - 2:30am ET
Saturday, 8/15/2009, 11pm - 2:30am ET
H21-100, H21-100, H23-600 (x4349)
Areas of Improvements & Updates
Stability
Notes
· Please treat this as a customer candidate
· H21-100: Medium Risk
· H21-200: Medium Risk
· H23-600: Medium Risk
· H21 MRV feature has been temporarily disabled.
· Please report all non MRV issues.
Stability
Notes
Previous Notes:
01 - Hide HD channels
02 - Network
02 - Media Share
02 - Music Screen Saver
02 - Game Search
02 - 1080p/24
02 - OTA via the AM21
02 - Autotune
02 - Multi-Room Viewing
:::::::View Playlist from a networked HR2x or R22
::::::layback/Trick Play functions from any networked HR2x or R22
::::::ress {LIST} to see HR2x or R22 servers one playback per server at a time
03 - Parental Controls when scheduling autotune
03 - MRV: bookmarks and resume playback from previous location
03 - Friendly name in network setup
03 - QuickTune
03 - Built-in Self Test
03 - Advance setup in remote control
Improved/Updated
01 - Future PPV Information
01 - Stability
02 - Autotune
02 - Stability
03 - Stability
03 - Support for more 1080p Sony TV models
03 - Faster Guide scrolling
03 - ATSC signal meter performance
03 - Fixed a screen saver issue
03 - ATSC setup screen now works on first boot
03 - Fixed reappearance of deleted autotunes
03 - UI updates ("tuner 2" and "tuner 3" references)
03 - Fixed Gray Screen or a PPV OSD appearing overnight
03 - Improved "Try Again" when trying to connect to the Internet.
04 - AV1/AV2 remote code refinements
04 - Improvements to DHCP network setup
05 - Issues with rebooting while in standby
05 - WGA600N Support
05 - Static IP Setup
06 - Stability
06 - Missing “Just a few seconds” OSD
06 - MRV playback and trickplay problems
06 - User Interface polishing
06 - Network services, Network setup, Network status
06 - One touch autotune via Enter key
07 - H21-100, SWM compatibility--will not affect other boxes
07 - H21-100, remote control support
07 - Removed “Reformatting Hard Drive" screen after Reset Everything
07 - Changing Display Language
08 - One touch autotune via Enter key
08 - WGA600N setup with WPA encryption
08 - Receiver not resetting
08 - Closed Captioning Loss
09 - Autotune on ATSC channels
09 - WGA600N setup with WPA encryption
09 - UI Improvements
09 - Missing spending limit unlock OSD
09 - SWM issue, Signal Strength H21-100
09 - System test H21-100
10 - Network Setup
10 - Autotune on ATSC channels
10 - Keyword search
10 - Screen flash coming out of Standby
11 - Improved Front Panel display on boot up
11 - IR Remote H21-100
11 - Remote setting when reset defaults
12 - PPV spending limit conversion (compared to national release)
12 - Video when switching to alternate audio
12 - Fixed blank reset everything screen
13 - Stability fixes
13 - Faster keyword search
13 - Reset everything warning message
14 - Autotuning when using parental controls
14 - Fixed "tune to 201" issue
14 - Reset defaults correctly sets the hide/show SD duplicates option
14 - Updated connection successful message in Network setup
14 - Stability
15 - Autotune Fixes:
::::::Manual with past start times
::::::Lingering icon after canceling
:::::arental Controls
::::::Minor polishing
15 - Updated welcome screen and help messages
16 - Autotune Scheduling with Viewing Hours set
16 - Preserve favorites when converting from NDS to DIRECTV firmware
16 - HDCP content protection H23-600
16 - Minor polishing
17 - Additional improvements to items from previous CE
18 - Scheduling autotunes
18 - Resetting the set-top-box in standby
18 - Call ID inconsistency
19 - Scheduling autotunes
19 - Coming out of standby
20 - Showings in Info Screen
20 - PPV autotunes when converting to new Middleware
21 - Improved tuning stability
22 - Under the hood
22 - MRV
23 - Aspect ratio changing on certain channels
23 - Bookmarks updates
23 - DIRECTV Subtitling (in TV options)
23 - Stability
24 - Autotune to XM Channels
24 - Stability
25 - Parental control
25 - Autotunes
25 - Stability
