H21 / H23 CE Release 4/17 v.42E7
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,043
448
Central Michigan
PLEASE READ THIS FIRST! DirecTV Cutting Edge Program: Terms, FAQ, How-To, Hidden Features, and More
If you have any issues with this CE release, please post them in this thread. We'll try to help, and DirecTV will see / be aware of your issue :)
For the latest updates, check out the Satelliteguys CE Chat on Friday nights:
chat.satelliteguys.us
H21-100, H21-200, H23-600 (x42E7) (CE #19)
(Release Dates 4/17 & 4/18, 11pm-2:30am ET)
Areas of Focus
• Showings in Info Screen
• PPV autotunes when converting to new Middleware
Notes
• H21-100: customer candidate
• H21-200: customer candidate
• H23-600: low risk download
• Going back to National will go back to default settings and lose local market ID setting
• Please report non-MRV issues only
• Please report abnormally low signal strength values; please specify whether the box is in FTM (SWM switch or SWM LNB) or Multiswitch environment (traditional switch or no switch, direct from LNB)
Previous Release Notes:
New features
01 - Network
01 - Media Share
01 - Music Screen Saver
01 - Game Search
01 - 1080p/24
01 - OTA via the AM21
01 - Autotune
01 - Multi-Room Viewing
:::::::View Playlist from a networked HR2x or R22
:::::::playback/Trick Play functions from any networked HR2x or R22
:::::::press {LIST} to see HR2x or R22 servers one playback per server at a time
02 - Parental Controls when scheduling autotune
02 - MRV: bookmarks and resume playback from previous location
04 - Friendly name in network setup
04 - QuickTune
05 - Built-in Self Test
13 - Advance setup in remote control
Improved/Updated
02 - Support for more 1080p Sony TV models
02 - Faster Guide scrolling
02 - ATSC signal meter performance
02 - Fixed a screen saver issue
02 - ATSC setup screen now works on first boot
02 - Fixed reappearance of deleted autotunes
02 - UI updates ("tuner 2" and "tuner 3" references)
02 - Fixed Gray Screen or a PPV OSD appearing overnight
02 - Improved "Try Again" when trying to connect to the Internet.
03 - AV1/AV2 remote code refinements
03 - Improvements to DHCP network setup
04 - Issues with rebooting while in standby
04 - WGA600N Support
04 - Static IP Setup
05 - Stability
05 - Missing “Just a few seconds” OSD
05 - MRV playback and trickplay problems
05 - User Interface polishing
06 - Network services, Network setup, Network status
06 - One touch autotune via Enter key
06 - H21-100, SWM compatibility--will not affect other boxes
06 - H21-100, remote control support
06 - Removed “Reformatting Hard Drive" screen after Reset Everything
06 - Changing Display Language
07 - One touch autotune via Enter key
07 - WGA600N setup with WPA encryption
07 - Receiver not resetting
07 - Closed Captioning Loss
08 - Autotune on ATSC channels
08 - WGA600N setup with WPA encryption
08 - UI Improvements
08 - Missing spending limit unlock OSD
08 - SWM issue, Signal Strength H21-100
08 - System test H21-100
09 - Network Setup
09 - Autotune on ATSC channels
09 - Keyword search
09 - Screen flash coming out of Standby
10 - Improved Front Panel display on boot up
10 - IR Remote H21-100
10 - Remote setting when reset defaults
11 - PPV spending limit conversion (compared to national release)
11 - Video when switching to alternate audio
11 - Fixed blank reset everything screen
12 - Stability fixes
12 - Faster keyword search
12 - Reset everything warning message
13 - Autotuning when using parental controls
13 - Fixed "tune to 201" issue
13 - Reset defaults correctly sets the hide/show SD duplicates option
13 - Updated connection successful message in Network setup
13 - Stability
14 - Autotune Fixes:
::::::Manual with past start times
::::::Lingering icon after canceling
::::::parental Controls
::::::Minor polishing
14 - Updated welcome screen and help messages
15 - Autotune Scheduling with Viewing Hours set
15 - Preserve favorites when converting from NDS to DIRECTV firmware
15 - HDCP content protection H23-600
15 - Minor polishing
16 - Additional improvements to items from previous CE
17 - Scheduling autotunes
17 - Resetting the set-top-box in standby
17 - Call ID inconsistency
18 - Scheduling autotunes
18 - Coming out of standby
Ruled out a bad receiver. I switched back to NR release last week, had no problems at all. This week, I've already lost signal 3 times. It's random, but happens when changing channels. Sometimes get a 721 error, sometimes just a blank screen. When I running test , it reports sats acquired, but at 0% signal. When viewing signal levels, all report 0%. This is an h23-600, with AM 21 connected directly to the LNB, no switches or SWM. (The AM 21 still stays on when powering off the receiver. :))
Thanks,
L.G.M.
P.S. Resetting is the only thing I've found that gets the signals back (which are normally in the mid 90's)
Question The record light on my HR21 has been yelow for the last two days what would cause it?
Thanks,
Greg
CE's for 5/8 & 5/9
HR2X & R22 5/1 CE v0304
