H21 / H23 CE Release 3/27 0X42E0
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,043
448
Central Michigan
Systems in this CE
H21-100 • H21-200
H23-600
Software Download Windows:
Friday, March 27, 2009 11PM - 2:30AM ET
Saturday, March 28, 2009 11PM - 2:30AM ET
PLEASE READ THIS FIRST! DirecTV Cutting Edge Program: Terms, FAQ, How-To, Hidden Features, and More
If you have any issues with this CE release, please post them in this thread. We'll try to help, and DirecTV will see / be aware of your issue :)
For the latest updates, check out the Satelliteguys CE Chat on Friday nights:
chat.satelliteguys.us
National Release Candidate for H21
Moderate Risk H23-600
New features
  • 01 - Network
  • 01 - Media Share
  • 01 - Music Screen Saver
  • 01 - Game Search
  • 01 - 1080p/24
  • 01 - OTA via the AM21
  • 01 - Autotune
  • 01 - Multi-Room Viewing
    • [*]View Playlist from a networked HR2x or R22
      [*]Playback/Trick Play functions from any networked HR2x or R22
      [*]Press {LIST} to see HR2x or R22 servers
      [*]one playback per server at a time
  • 02 - Parental Controls when scheduling autotune
  • 02 - MRV: bookmarks and resume playback from previous location
  • 04 - Friendly name in network setup
  • 04 - QuickTune
  • 05 - Built-in Self Test
  • 13 - Advance setup in remote control
Improved/Updated
  • 02 - Support for more 1080p Sony TV models
  • 02 - Faster Guide scrolling
  • 02 - ATSC signal meter performance
  • 02 - Fixed a screen saver issue
  • 02 - ATSC setup screen now works on first boot
  • 02 - Fixed reappearance of deleted autotunes
  • 02 - UI updates ("tuner 2" and "tuner 3" references)
  • 02 - Fixed Gray Screen or a PPV OSD appearing overnight
  • 02 - Improved "Try Again" when trying to connect to the Internet.
  • 03 - AV1/AV2 remote code refinements
  • 03 - Improvements to DHCP network setup
  • 04 - Issues with rebooting while in standby
  • 04 - WGA600N Support
  • 04 - Static IP Setup
  • 05 - Stability
  • 05 - Missing “Just a few seconds” OSD
  • 05 - MRV playback and trickplay problems
  • 05 - User Interface polishing
  • 06 - Network services, Network setup, Network status
  • 06 - One touch autotune via Enter key
  • 06 - H21-100, SWM compatibility--will not affect other boxes
  • 06 - H21-100, remote control support
  • 06 - Removed “Reformatting Hard Drive" screen after Reset Everything
  • 06 - Changing Display Language
  • 07 - One touch autotune via Enter key
  • 07 - WGA600N setup with WPA encryption
  • 07 - Receiver not resetting
  • 07 - Closed Captioning Loss
  • 08 - Autotune on ATSC channels
  • 08 - WGA600N setup with WPA encryption
  • 08 - UI Improvements
  • 08 - Missing spending limit unlock OSD
  • 08 - SWM issue, Signal Strength H21-100
  • 08 - System test H21-100
  • 09 - Network Setup
  • 09 - Autotune on ATSC channels
  • 09 - Keyword search
  • 09 - Screen flash coming out of Standby
  • 10 - Improved Front Panel display on boot up
  • 10 - IR Remote H21-100
  • 10 - Remote setting when reset defaults
  • 11 - PPV spending limit conversion (compared to national release)
  • 11 - Video when switching to alternate audio
  • 11 - Fixed blank reset everything screen
  • 12 - Stability fixes
  • 12 - Faster keyword search
  • 12 - Reset everything warning message
  • 13 - Autotuning when using parental controls
  • 13 - Fixed "tune to 201" issue
  • 13 - Reset defaults correctly sets the hide/show SD duplicates option
  • 13 - Updated connection successful message in Network setup
  • 13 - Stability
  • 14 - Autotune Fixes:
    • [*]Manual with past start times
      [*]Lingering icon after canceling
      [*]Parental Controls
      [*]Minor polishing
  • 14 - Updated welcome screen and help messages
  • 15 - Autotune Scheduling with Viewing Hours set
  • 15 - Preserve favorites when converting from NDS to DIRECTV firmware
  • 15 - HDCP content protection H23-600
  • 15 - Minor polishing
  • 16 - Additional improvements to items from previous CE
Notes
  • Reverting back to National Release will go back to default settings
  • To enable MRV:
    • [*]Network must be enabled
      [*]Enable IAMANEDGECUTTER keyword
      [*]Select Menu -> Parental, Fav's & Setup -> Miscellaneous Options -> Multi-Room DVR and choose On.
      [*]Network must be enabled on HR2x and R22 DVRs
  • Please report non-MRV issues only
Seems stable so far. I'm guessing the AM21 staying powered up is a permanant feature because it's still on when powering the receiver off. h23-600 & AM21. Haven't lost video when changing channels at all with this release.
Take care,
L.G.M.
H21-200
DK: 20090329-236A
seems like a national candidate :up
And again, spoke too soon. Lost video on all channels with a 721 error last night. Restarting clears it up, but it's aggravating - if only because it's so random. Only improvement I can see is that I'm at least getting an error message now instead of just a blank screen. I've moved this receiver to other locations in the house and still get the problem. So, I don't believe its a cable issue. Might be a faulty receiver.
Thanks,
L.G.M.
CE's for Thursday 3/26 - 3/28
HR Networking question
