H21-200 CE Release 1/23 0x42AB
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,043
448
Central Michigan
Systems in this CE
H21-200
0x42AB
Window of opportunity to download:
Friday, January 23, 2009 11:00PM - 2:30AM ET
Saturday, January 24, 2009 11:00PM - 2:30AM ET
PLEASE READ THIS FIRST! DirecTV Cutting Edge Program: Terms, FAQ, How-To, Hidden Features, and More
If you have any issues with this CE release, please post them in this thread. We'll try to help, and DirecTV will see / be aware of your issue :)
For the latest updates, check out the CE Chat on Friday nights:
cechat.satelliteguys.us
The Contents of this CE Download: (Differences based on last National Release)
  • Items from CE:17:01 High Risk
  • Items from CE:17:02 High Risk
  • Items from CE:17:03 High Risk
  • Items from CE:17:04
  • Items from CE:17:05 High Risk for H21-100 Moderate Risk for H21-200
  • Items from CE:17:06 High Risk for H21-100 Low Risk for H21-200
  • Items from CE:17:07 Moderate Risk for H21-200
New features
  • 01 - Network
  • 01 - Media Share
  • 01 - Music Screen Saver
  • 01 - Game Search
  • 01 - 1080p/24
  • 01 - OTA via the AM21
  • 01 - Autotune
  • 01 - Multi-Room Viewing
    • View Playlist from a networked HR2x or R22
    • Playback/Trick Play functions from any networked HR2x or R22
    • Press {LIST} to see HR2x or R22 servers
    • one playback per server at a time
  • 02 - Parental Controls when scheduling autotune
  • 02 - MRV: bookmarks and resume playback from previous location
  • 04 - Friendly name in network setup
  • 04 - QuickTune
  • 05 - Built-in Self Test
Improved/Updated
  • 02 - Support for more 1080p Sony TV models
  • 02 - Faster Guide scrolling
  • 02 - ATSC signal meter performance
  • 02 - Fixed a screen saver issue
  • 02 - ATSC setup screen now works on first boot
  • 02 - Fixed reappearance of deleted autotunes
  • 02 - UI updates ("tuner 2" and "tuner 3" references)
  • 02 - Fixed Gray Screen or a PPV OSD appearing overnight
  • 02 - Improved "Try Again" when trying to connect to the Internet.
  • 03 - AV1/AV2 remote code refinements
  • 03 - Improvements to DHCP network setup
  • 04 - Issues with rebooting while in standby
  • 04 - WGA600N Support
  • 04 - Static IP Setup
  • 05 - Stability
  • 05 - Missing “Just a few seconds” OSD
  • 05 - MRV playback and trickplay problems
  • 05 - User Interface polishing
  • 06 - Network services, Network setup, Network status
  • 06 - One touch autotune via Enter key
  • 06 - H21-100, SWM compatibility--will not affect other boxes
  • 06 - H21-100, remote control support
  • 06 - Removed “Reformatting Hard Drive" screen after Reset Everything
  • 06 - Changing Display Language
    [*]07 - One touch autotune via Enter key
    [*]07 - WGA600N setup with WPA encryption
    [*]07 - Receiver not resetting
    [*]07 - Closed Captioning Loss
Known Problems
  • 02/06 - Support for WGA600N
  • [strike]02 - DHCP network setup[/strike]
  • [strike]04 - Network Services may not work[/strike]
  • [strike]05 - Diagnostic reports do not work[/strike]
  • [strike]05 - H21-100, intermittent “Searching for Satellite” OSD[/strike]
  • 06 - H21-100, signal strength screen
  • 06 - H21-100, may lose satellite signal after several hours requiring reset
  • 07 - WGA600N setup with WEP encryption
Notes
  • 01 - Reverting back to National Release will go back to default settings
  • 01 - To enable MRV:
    • Network must be enabled
    • Enable IAMANEDGECUTTER keyword
    • Select Menu -> Parental, Fav's & Setup -> Miscellaneous Options -> Multi-Room DVR and choose On.
    • Network must be enabled on HR2x and R22 DVRs
  • Please test the box as a standard H21 before enabling the Multi-Room View Client feature and report issues
  • Then please test MRV (veggies before dessert)
  • When reporting MRV issues, please include the logs from both server and the client
  • 01 - Please report all occurrences of “Unable to Access to Media” OSD with logs
  • When reporting issues with 1080p, please include the TV resolution information reported from the Miscellaneous Options screen as well as your TV model number
*** CAUTIONARY NOTE *** You've been warned
  • 01 - Do not have an unpurchased PPV in the server’s playlist when displaying the playlist on the H21
  • 01 - Do not have a currently downloading broadband program in the server’s playlist when displaying the playlist on the H21
  • 02 - The above Cautionary notes are less cautionary
CE's for 1.23 & 1.24
DirecTV's 1080p via VoD
