I recently made a DIY antenna that works really well & picks up all the OTA stuff on my TV. So, i figured with that said & done, I could implement 2 diplexers on my satellite line and setup this antenna on my roof for optimal reception. I have a 5 LNB Slimline dish (standard, not SWM)
i started this morning by placing one diplexer on the TV side by doing this:
H21-100 with B-Band adapter & TV antenna -> Diplexer -> RG-6 -> Dish
with the diplexers in place, i got an error with 501 (HBOeHD) trying to find a signal and other HD channels working. I figure... ok. Maybe its the placement of the B-Band adapter.
I moved the B-Band adapter to the other side of my inside diplexer and lo & behold, i got the channel back. When it came to install the diplexer on the opposite end, i did the same thing... i added the diplexer to the dish & antenna and yet again, i got an error with HBOeHD.
Is there a way around this with the Slimline 5-LNB? or is it pretty much hopeless for me because of the b-band adapter? if there's a solution, can u show me a diagram?
Thanks!
Thanks!
