Guide Questions
rracer5
9
Full time RV'er
I fulltime in an RV and used Slimeline dish with a 5LNB non-SWiM "head" with 4 individual leads (I only used 2) and everything worked fine. Today, I switched over to a 3 LNB SWiM "head" with power inserter and DC pass thru splitter. I changed both of my H21 receivers to the 3 LNB SWM setting and so far, everything is working OK except the guide is not updating with current programming. I'm getting a 920 error. Any input on this?
Did you remove the b-band convertors? What are your signal levels on all the sats?
Signal strength is high 90's - 100 on the 101 sat. & 95-96 on the 99ca(b) & 101ca(b). No b-band converters....I took them off. Now my wife tells me the guide on the bedroom TV is OK....just the livingroom box not complete......baybe just a little slow filling in after making changes?
It can take a while to propagate, up to 24 hours.
New install questions
New DIRECTV Receiver from Technicolor LC61 and LH44
