When I got my first dish 4.5 years ago the installers ran the coax down the side of my house. The coax was then ran through a mounted block that was connected to another ground wire on the house. I now have my new setup. It's two seperate dishes (one at 72.5). The coax is different though. There seems to be a approx 14-16ga. ground wire ran with the coax. It's all coated together but peeled back some. My wires run into my attic where they are connected to a multiswitch. Neither of the ground wires (I'm guessing that's what they are) are connected to anything. What's the best way to hook them up? Can I just tie or solder them together & run them back down my house with an extended wire to my previous grounding spot? The multiswitch appears to have a ground wire screw on it. The multiswitch is mounted to the rafter so I doubt that would do much good there, but does the switch need to be grounded too? Or will it be OK, if I just connect the two small wires outside like before?
The other setups I've seen look like my old setup where the actually coax appeared to be grounded. These new small wires have me confused. Not really sure why the installer never did anything with them.
Thanks,
Thanks,
