I currently have a 2 HWS + 2 Joey setup using a Duo node. I am wanting to add a DPP44 switch so I can also hook up my 211z (from my tailgater) at home. I noticed in the image above it shows the DPP44 being grounded.
Must the DPP44 be grounded to work? I was going to install it in the wiring panel inside my house at the same location as the Duo node.
A little extra info if this is relevant:
My Dish antennae is not grounded. When the antennae was installed years ago it was placed high up on my roof because that was the only spot that could get a clear signal due to trees but it was too far away to ground. The trees are gone now and I plan to move the antennae and properly ground it when I upgrade to Hopper 3 in the next year.
