Just remember that by what you're doing splits the signal by 2 and has a loss of 3 dB. It will reduce the signal by some.
 That's a small change in signal and I wouldn't worry about it. If it changes by several dB then I would be concerned. Electronics and software other variables can cause a difference that much, again don't worry unless it's by more then a dB over a long period of time.
Question for ya KWX, Are you using the TBS driver for that 5925?
I think crazycat made one for it as well with his crazyscan.
I can keep that in mind but I may also go a different route then that, I'm keeping my options open.
I trying to stick with a separate receiver from the computer.
 My signal is as strong as yours there KWX... That's what I've been saying. That's the difference of the two receivers. I got plenty of signal but the receiver is dropping the BBF's. It's the receiver's problem not an antenna issue.
   Keep in mind that Brett got even with a weak weak signal (by about 1.5 dB C/N less) BBF's from his card and data. That's saying something.
  My TBS receiver is not set up for generic stream, even though TBS claims it to be. It's more geared towards MPE.
Unfortunately I had to find out the hard way.
I am also going to pose this question..
 On my NOAAPORT station the BER will scroll up if the signal gets degraded resulting in data loss.
Here's the question,
Why is it with the generic stream that even though you have no DVB-S2 BER's that there's bad BBF's?
 In other words, how come you see no errors on the error rate on the outer layer DVB-S2 but have errors on the inner layer, It makes no sense.
Unless you're having hardware errors/drops.
 ....And lot of cool stuff to go with it.
 The schedule will be out soon with the details, as soon as I see it I will post it here. It takes several weeks for it to even get to geostationary orbit.
  My thought is it will be farther west but KWX may be right as well, we'll see as the info becomes available.
