Glad to hear that you got your system working Dr Pepper 6044. I got me a new SonicView Premier receiver for only $50 shipped and a SkyWay dish with lnb for free from a friend that no longer needed it which uses FSS signal at 105. I also have an old lnb I used to pickup locals off of 105 on Dish Network several years ago that I had bought that I had bought new back then for the FSS satellite and hope it may work as well.
I also have a First Strike meter and hope I have the right settings to start tinkering with this here where I am at to receive a signal so that I can install these for others. I hope there is a big enough demand here where I am to do some installs in my area. If the demand is big enough then I would become a Glorystar dealer.
On these transponders that have to be tuned in, are there certain ones that are in between that would best be used to peak on that would equally balance the other ones out? For example, one has already determined that you should not peak any of them, that you should balance them out to 50%. As you increase one you drop another. Wouldn't there be a transponder that could be used to peak the signal that would be more close to the middle?
