Hi, I'm in the process of adding my 4th receiver to my G* system . Previously I had 2 Merc II (on the upper floor level) that were slaved one to the other via the loopthrough. (Worked "OK" if both receivers were on the same bird!) The feed came from 2 dual output LNBF's connected to a Diseqc switch. The 3rd receiver a Geosat Pro 1000 (located on the lower floor level) was connected to a 2nd Diseqc switch that got the other pair of coax from the 2 dual out LNBF's.
Now that I'm adding yet another receiver to the mix I decided to do it right and got a Zinwell 4x8 Multiswich (SAM-4803) The Merc's which have a much shorter run to the switch are happy... they can go back and forth between AMC4 and G25. The Geosat on the other hand AIN'T happy... it connects to AMC4 just fine but doesn't get a signal from G25. Granted I have a long cable run to the Geosat rec. (due to distance and location around the house) of somewhere between 150' - 200' of RG6 with a little booster amp inline. The long cable run with the little booster has worked just fine with the previous config with the Diseqc but now the Geosat cannot get a signal from IA5 using the 4x8 multiswitch.
I don't think the length of the long cable run IS or Should be an issue per se but I'm not sure. I'm pretty certain the switch is functioning "fine" as the Merc's are happy though Geosat only sees AMC4.
Any thoughts from you FTA SUPER-SLEUTHS!!!
