Team,
Offering GEOSATpro spring sale for hobbyists, conversationalists and enthusiasts:
Any order pay flat rate shipping only $14.50 total for the whole order!
If you order two or more of the same item, you get 10% off!
GEOSATpro 90cm / 36in offset dish - awesome for Ku Band (actual dimensions 85cm x 93.5cm) - $75
Ku Band LNBFs
GEOSATpro SL1PLL Single Output Ku/Linear/Standard/LO 10750 PLL Phase Lock Loop - $17.00
GEOSATpro SL2BLT Dual Output Ku Band Linear/Standard Bullet LO 10750 DRO - $29.00
GEOSATpro SL2PLL Dual Output Ku/Linear/Standard/LO 10750 PLL Phase Lock Loop - $28.00
GEOSATpro SL1 Prime Single Output KU Band Linear/Standard LO 10750 For Prime Focus - $18.00
GEOSATpro UL1PLL Single Output Ku Band Universal LO 9750/10600 PLL Phase Lock Loop - $16.00
GEOSATpro UL2PLL Dual Output Ku Band Universal LO 9750/10600 PLL Phase Lock Loop - $20.00
C-Band LNBFs
GEOSATpro C1 Single Output C-Band LO 5150 DRO (OLD MODEL - only 8 left!) - $10
GEOSATpro C1 Phase Lock Loop (NEW MODEL) Single Output C-Band LNBF - $22.00 (Free sample if promised honest evaluation on Satelliteguys.us - Free evaluation offer ends Monday March 2st end of business day)
GEOSATpro C2 Phase Lock Loop (NEW MODEL) Dual Output C-Band LNBF - $34.00 (Free sample if promised honest evaluation on Satelliteguys.us - Free evaluation offer ends Monday March 2st end of business day)
Other Supplies
C-Band LNBF Generic Conical Feedhorn for offset dish - $18
CLAMP-CBAND MOUNT C-Band LNB Feedhorn Clamp for Offset Type Satellite Dish - $6.00
CLAMP-4DEG LNBF CL GEOSATPro 4 Degree Rotating Dual LNBF Clamp. For use with GEOSATPro 90cm Dish & SL2BLT LNBFs - $5.00
CLAMP-3LNBF MOUNT - Triple Offset Bracket for 40mm LNBFs - Suitable for mounting 1, 2 or 3 on one dish (Use up to two 3LNBF Mounts for 6 LNBFs!) - $10.00
CLAMP 40MM LNBF CLAMP Single LNBF Clamp fitting all GEOSATpro dishes and 3LNBF mounts - $10.00
SWITCH-SW24 2x4 Multiswitch - GEOSATpro - Connect up to four receivers to Dual LNBF - $15.00
SWITCH-SW21 2x1 22Khz Ecoda Switch - $10.00
SWITCH-SW41 4x1 DiSeqC Switch GEOSATpro - $4.00
SWITCH-SW81 8x1 DiSeqC Switch GEOSATpro - $16.00
SWITCH-44 4x4 22Khz Ecoda/GEOSATpro Multiswitch - $15.00
If you are not satisfied with the product, please return it within 30 days and we will refund your item cost.
888-483-4673 - 7:30am - 4:00pm Pacific Time
For details and support, send private message.
Ku Band LNBFs
C-Band LNBFs
Other Supplies
