I don't get it. It's 104. No calculator needed. What am I missing? (100-0+4)
and that is the correct answer. Why? Because the parens aren't there for Pemdas to apply, that's why. Without parens the mathematical calculation is linear.I must be a retard cause I came up with 79
This is a false statement. PEMDAS applies whether or not parens are present.Because the parens aren't there for Pemdas to apply, that's why.
PEMDAS DOES NOT REQUIRE PARENS! It speaks to how to deal with them whether or not they appear in the equation. By your definition, don't the other five operations also have to be present?What does the "P" stand for? Yep, parenthesis is the first requirement.
Statistics is the manipulable side of Mathematics much like Finance is the dark arts subdivision of Bookkeeping.I here I thought statisticians were artists
What does the "P" stand for? Yep, parenthesis is the first requirement. If you don't have them it does not apply. Go back and look at the examples. Where you put the parens affects the result so without them you have no option other than a linear calculation. Don't ever try applying that Pembas nonsense in any engineering calculations unless you include the parens.
Simple math for the mathmatically challenged. You get 50 bucks then you get 50 more. Now you have $100. You spend $25 so now you have $75. You invest it but make no interest (x0) so you still have your original $75. Now add $2 and then add another $2. Now you have $79. That's the real world.
Here, read what Harvard has to say about the ambiquity of Pemdas:
Ambiguous PEMDAS
If it's ambiquous it has no place in math. Math is an exact science, not an art. If you really want to get confused read about Bodmas {Brackets, Order, Division/Multiplication, Addition/Subtraction}.
Ambiguous PEMDAS
BODMAS is an alternative nomenclature for PEMDAS that is confusing because it uses "brackets" to describe parens and "orders" as a substitute for exponentiation. In the US we typically don't use these terms in this way.
Now that "New Math" (a variant on "rods" that were used when I was young) is out the window, the book publishers needed some device to sell new books. Foolishness.My daughter who is now in 9th grade was taught GEMDAS, so nowadays you don't use PEMDAS or BEMDAS or BODMAS. G is for grouping.
There's no ambiguity. The fifth grade teacher is wrong and the reason the teacher is wrong is that they took short cuts in expressing the multiplications in the algebraic expression. In this case the 2x and 3y are representations of (2*x) and (3*y). Assigning a higher precedence to multiplication versus division (M comes before D) can help with this.If it's ambiquous it has no place in math. Math is an exact science, not an art.
Dragging how certain software handles expressions doesn't change how the expressions should be evaluated, just how the software itself should be looked at (as I mentioned above in my Excel example).
Another example of blog clickbate.
