Hi, I have a gbox positioner that moves a harl/powerjack 24" 36v actuator on a 6ft dish. Recently its been flaking out, losing count and randomly the gbox has thrown an E-2 error (its only error). Now all it does is throw the E-2 error when you try and move the dish.
Wiring is fine (tested). Tried testing the read and during testing I noticed that the gbox is throwing 16volts out to the reed sensor even when the gbox is turned off. Can anyone verify that it should be throwing 16volts even when the power botton has been hit and the unit is turned off? I always thought the reed sensor simply sent pulses as a magnet spun next to it.
Thanks for anyone who can check this out on their gbox or similar setup. This isnt making sense and I want to track the problem down to the reed switch or the gbox.
thanks!!
thanks!!
