Galaxy 27Ku and Pansat 2700a
Bennie
17
I bought a new 31 inch dish with a KUL.1 .4.4db LNBF. I want to watch White Springs TV on Galaxy 27 Ku. My newbie question is that Galaxy 27 is not listed in the satellite list on my Pansat 2700a. Is Galaxy 27 known by another name on the Pansat 2700a list?
If Galaxy 27 is not known by another name then I assume I have to manually enter the satellite information into the Pansat 2700a?
If it has to be manually entered what do I enter for the "LNB Local-Freq" ? And, do I leave the TP setting to the default "TP 1" or should I use another for setup?
I realize this is a lot of questions but I am at a loss on setting up White Springs TV.
Thanks,
Bennie
G27 formerly IA7 formerly T7 :)
If you need to set a new satellite up, the LNB Local Frequency would be 10750 STANDARD
check thelist for the info for White Springs and you can manually enter it. Even if T7/IA7/G27 is in the satellite list, the transponder info for WSTV may not be right and you'd have to edit that info
using a multi lnb braket on a Winegard DS-2076 31" (76cm) Dish?
Friday FTA Fun Poll 4/18
