I've recently had to change Galaxy 25's position from 97.0 to 97.6 in order to get a respectable signal. At first I thought that perhaps the wind knocked my dish out of alignment however all the other satellites that I'm hitting did not require an adjustment. Does anyone have an explanation as to why I had to make an adjustment to just one satellite? Did Galaxy 25 "drift" out of position?
I assume that you're talking about Galaxy 19, since Galaxy 25 is at 93, not 97.
It definately wouldn't be that far off. According to Space-Trak, it is between 97.03 to 97.11 , based on keps that are less than 3 days old.
   Usually, when people experience problems like this, it's because there is interferrence from a signal on some nearby sat, and moving the aim off the correct aim affects the interferrence more than the signal you're looking for.
Also a possibility is that sometimes the motors seem to forget where they are, and you need to send it to zero to remember.  Also, sometimes motors go to different places if you're going there from different directions, due to free play in the gears.
All the above are possibilities, but it seems like sometimes the darn motors just do what you describe for no logical reason.  I've seen that happen on several occasions, just on one sat, for a few days.  Never did figure out why. But I'm confident that it isn't the sat moving.
