galaxy 11 question
ELMWOOD
59
Hi, I'am starting to really get the hang of this true wild feed thing. My question is though I have satellite nimiq 1 set up as a sub. I stay on this sat and make a new sat in my settings and call it 91 ku. I have added all the transponders and see a live wild feed on Ricks wild feed site is running. I add the info but I still get nothing for quality on the ku side of 91? Is this bird all HD? I just can't understand it maybe since I have nimiq1 going it messes it up? I have all the settings correct in antenna settings.
You would need to be on Galaxy 11 which is the same orbital slot but KU :)
You mean Linear :)
If you upgraded your dish to a 30 inch+ and swapped out your current lnb at 91 with a Invacom quad, then you can use the circular output for your sub and the linear output for G11.
Plus, it should increase your signal for Nim1 :)
Ok, I have a ivacom lnb set at 11750 for the ku transponders. I get 87 percent quality on the circ side but nothing on ku. I guess I will have to mess with settings or something.
Thanks for the help guys.
Aiming Dish
need help
