OK, I might have gotten this partially figured out. Looks like my servo motor not switching between H and V. I turned the lnb about a 20 degree turn and got the V channels on the FTA.
I also used the ant. setup using LNBF and was able to get about 7 channels but then switched it to Normal and was able to pickup about 13 along with some radio stations.
One other question, does it make a difference when you are mounting the lnb to the dish as to something pointing up or down? As long as your servo motor is working, isn't that suppose to automatically tune in the channel?
Bob
