G3 reception
john dusek
112
east bernard Texas
as you know a lot of stations have moved to G3. I have noticed on most of the channels at times the picture gets a few squares and then the picture is normal again. (it acts like when wind is blowing) (no wind) It is very minor and barely interups the picture. It is worse in morning. No trees, have tried by adjusting the antenna, have also tried tipping the antenna a little up and down (which I have used in the past to adjust my othe KU channels. All othe channels and KU ones work perfect. Am close to Houston TX and am wondering if if the sat is having trouble or the sun is causing it.
Need to know if any one else is having and type of trouble.
Thanks John
Truckracer,hope your GTO is still running the low ETs. Think focal point is ok since I get all other Sats good (X4 KU in high (90s) Its doing fine today(with no adjustments) I guess it was other type interferance. (when it was acting up the sig strength was in the 90s and would drop to 40s at times,some times it would happen so fast the sig didnt have time to change. AS Red Buttons used to say strange things are happening. I think I have a in line sig amp (put it in for FTA) before I found out it was my fuzz buster causing problems. Could the amp be making the signal too strong?(it workes ok on all other sats) Looks like no one else is having problems with G3.
Thanks for come back, John
I now get both polarities off a LNBF to my C-Band receiver
How long to let channel maps download??
