g10r signal- lower than normal?
Hi,
Any input would be appreciated.
I was just working to peak my first FTA setup on G10R over the weekend and having a frustrating time getting much of a peak. T5 peaks fine. The only channels I could receive at all on G10R were at 11805 (Research & UWTV) and they were spotty at best. By sunday night, with no further adjustment on the antenna, these two channels were solid. By monday night, 6/5, the two Fort Smiths at 12114 were solid as well (again with no further antenna adjustment). I seem to have the antenna peaked on the receiver signal indication for Az, El and Skew but the most signal I can get at 11805 is 20%. I am in AZ.
Reading this thread and other posts regarding G10R, I'm gathering that even in the best of times this satellite is among the weakest. Would like to get a better sig as it looks like one of the best FTA satellites around. Is G10R still operating at reduced reception on monday 6/5 or today, tuesday 6/6?
I would really like to get the set at 11720 and 11800 but I can't get any signal at all beyond an occasional momentary 10% peak. Should I expect further improvement with adjustment? I've been trying to find a higher peak for days on these two transponders but so far I am unable to find anything beyond the skew that has provided the highest peak on 11805 so far.
My setup:
Wave Frontier T90
Invacom QPH-031 at the center of the LNBF-rail
(Linear ports ONLY, already know not to use the circular ports)
PanSat
Incidently, this is my first satellite system used since I was a freshman in high school. It was 1978 and I was a faithful reader of Coop's Satellite Digest. I built the spherical antenna he published, a single-conversion receiver (avantek VCO, Mini-Circuits passive mixer), a demodulation board built with discrete transistors, and a three stage LNA with (then unheard of!) 0.7dB NF Mitsubishi GaAs FETs. It didn't work well but I could receive the strongest transponders in the clear and others with noise. Being in Alaska with a 14° elevation to a 5W satellite didn't help but it was fun as the channels weren't scrambled yet (it was even before VideoCipher I). Life moved on and I haven't done anything with this since- looks like I've missed quite a boom in the industry!
Hi,
My setup:
Wave Frontier T90
PanSat
