G 10 R/Ku
black Bear
33
Hello All
Was hoping if you could help me get set up .. I have a Pansat 3500sd ..I tried for hours yesterday to receive G10 R/Ku with a 35" oval star choice dish with pop can lnbs ..Should i be able to intercept this without a skew ? I had tried both lnbs but not sure which was the correct one .. I was also reading today that i should be leaving it for 5-10 seconds before moving it another degree ..
After all of my hard work the only thing that i had a 99% quality reading was superdish at 121 W ..
Maybe i did not have the antenna settings correct ?
I just wanted to test this star choice dish before i went out and purchased a wingaurd dish with motor and invacom ..
Any help would be appreciated ..:)
The nice folks here will definitely get you straight if I am misaken but I believe that LNB is circular polarity for DBS satellites which is why you can pull in 121 fine. The 35" dish is fine I think you just need a cheap linear LNB skewed properly and you'll be in business. Sit tight till the experts chime in.
:hatsoff:
You should be able to pick up G10 with the beer can LNB :D
121W is linear as is 123 so you should be fine.
Skew is critical and if its not skewed, it will be a bugger to pick up
On the 3500 you would set it up as standard with a LNB LO of 10750. Turn the rest off (Diseqc, 22k, motor)
Select the following tranponder
11799 freq
V polarity
26660 symbol rate
Since you got 121 with a 99% (I don’t know if that’s right…best I can get 121 is 78% quality) you would move the dish a smidge to the west
Thx for the replies !
Now standing behind the dish looking at the birds , should i use the lnb on left or one on right ? Also i am going straight from lnb to stb .. There is a switch on the arm of the SC dish , am i supposed to use it or not ..
Another thing that is puzzleing me was am i supposed to rename each sat so it goes into the selected satellite area before i scan .. I noticed that when i selected G 10 and went to signal meter page it then placed G10 automatically in the selected sat area , is this what is supposed to happen ? Thx again !:)
use the one on the right (if you're standing behind the dish) and remove the switch. That screws it up. Hook the coax directly to the LNB
yes that is normal :)
Thanks so much Iceberg , when i get another chance i will give er' another go !
Do you think that G10 @123W is very close to the Super Dish @121W area ?
Hope I'm not asking to much here !:up
123w-g10r
yes, it is very-very-very close
you need to aim your dish more down & right (standing behind) just by about 1/8" >>>>>>G10 will be there.
signal meter is probably useless, because it will pickup the stronger Echostar 9signal
once you get it, you will see that it was worth all your effort
Iceberg, I have never been able to get G10R. I moved my dish on the mast, switched lnb's, went thru every LO frequency with no luck. I did get quality signal on 121 though. If I got signal on 121, wouldn't I be able to get it on 123? The dish doesn't move that far. Also, if I have a motor I shouldn't need to scew the lnb since the motor does that automatically by turning the whole dish and lnb together. I broke down and ordered an Invacom qph 031 lnb. I hope that will make a difference. I noticed that the tp you listed above wasn't in my CW600s's list of tp's for G10R, so I added it. Still nothing. I would really love to get that sat.
correct. 121 to 123 is maybe 1/8"
correct. The motor skews the lNB automatically
the TP can be one of a few
11799 V 26660
11800 V 26660
its the same TP. Otherwise you can add it manually :)
When I ws going for G10, I was on G13 I think (the next bird over), and it was just a very lite tap - I actually didn't think I had even budged the dish, thats how little of movement is needed. Kinda weird to think that little movement would make all the difference!
VERY small movements make a big difference. Actually, many members looking for G-10R first get 121w, then move the dish SLIGHTLY to the west until barely loosing quality on 121w. Rescan and you'll get G-10R :)
New to FTA !! C Band !!
Any Bull Fighting On FTA?
