I have a Pansat 3500 and a Fortec Star 32" dish on a rotor. The signal strength on the 3500 meter tells me I have a strength level of 92 and a quality level of 75, just for example. (strength actually varies from one channel to another).
If the cable between the antenna and the 3500 is no longer than about 25 ft. the picture quality is fine. When I move the receiver to inside the house with a 125 ft cable the signal drops off by approximately 1/3 and begins to drop channels.
The longer cable is new and it checks out fine for continuity. Could the problem be in the 3500?...Perhaps it is not able to support a long cable, or should I be looking someplace else.
Is there any type of "signal amplifier" that will work with an FTA receiver with a rotor. Also, as time goes on I want to use a DiSecq switch to combine this receiver with the c-band BUD, which has an even longer cable into the house.
